work centre 7120 error codes 092-315 ATC K fail
  • copytech200X
    • 264
    Anyone encounter this error codes for above model?
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Re: work centre 7120 error codes 092-315 ATC K fail
    Black toner very low
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
    • adriansto
      • 2369
      - plastic seal not removed from toner cartdrige
      - failed black drum unit
      - dirty drum gears
      - black dev. drive clutch slipping.
      • vodo
        • Dec 2016
        • 36
        Your Black auger assembly needs to replace. The white tab at its end, broken or felt off which gave machine error.
