Xerox WC3325 stuck in initialization
  • Lbcoaster
    • 43
    [Misc] Xerox WC3325 stuck in initialization
    Hello, I have a Xerox WC3325 stuck in initialization, it turns on but stays in the initializing state, got it to pass that stage one time entered web page updated firmware it was stuck in that for several hours... any thoughts, suggestion andor help will be greatly appreciated!
    Steve
    Coast Copier
  • Lbcoaster
    • 43
    Re: Xerox WC3325 stuck in initialization
    No ideas?
    Steve
    • prismtech
      • May 2014
      • 199
      Start with the firmware drive.
      Sent from my SM-J120W using Tapatalk
      • Lbcoaster
        • 43
        [QUOTE=prismtech;557974]Start with the firmware drive.
        is there a way to flash the firmware, I am unable to do an update through the web page it will not go past the initializing
        Thank you
        Steve
        • prismtech
          • May 2014
          • 199
          I dont work with the small little units.
          In a larger workcentre you would perform an altboot from usb media. Google for instructions.
          The symptoms your having could very well be associated with failing firmware drive. Firmware reloads are useless until you fix the drive.
          When this happens to a "Staples" level Xerox you may also just be better off tossing it and grabbing another one. Its a 300 dollar unit on sale. Why bother?
          • prismtech
            • May 2014
            • 199
            $277.00 new on Amazon. Giving them away.
            • Lbcoaster
              • 43
              understood, sold them a HP unit that will work well for what they do.
              Most of what I was trying to do was to see if I can easy fix for my tech ego and use as a loaner if needed...
              thanks
              • prismtech
                • May 2014
                • 199
                Smart move! Nothings usually an easy fix with a non-booting consumer grade Xerox.
                We call them Dixie cups for a reason. Use them. Squish them. Toss them.
                • Exok
                  • Jun 2011
                  • 750
                  Is this the one that uses a small flash drive in place of an HDD? Try replacing that and then reloading software.
                  • Lbcoaster
                    • 43
                    Yes and I believe it's a problem with the software on that flash drive do you have access to the software or can direct me where I can download it
                    I am unable to access the machine via the computer in this condition.
                    thanks Steve
                    • akos
                      • Apr 2017
                      • 8
                      This error only resolved when replace main pwb.
                      • Lbcoaster
                        • 43
                        Thanks!
                        I did put in a blank flash drive and it did come out of initialization and looks like it whats you to start the set up but then it goes into a loop and repeats this...?/
                        • akos
                          • Apr 2017
                          • 8
                          Originally posted by Lbcoaster
                          Thanks!
                          And if you place back the original flash drive in this state?
                          • Lbcoaster
                            • 43
                            When putting back the original flash drive it once again gets stuck in initialization
                            • akos
                              • Apr 2017
                              • 8
                              Sorry for my mistake! I found Eureka tip for this problem. If this message appear only on display there is a problem with USB drive. The part number of this: 007N01809
