Advice Needed: Workcentre 7120 / System Error 092-315 on main display
  • rockdude
    • Feb 2011
    • 257
    I am getting a system error 092-315 on the main display on startup. Which indicates a ATC Fail (K) Black.
    The error codes list states the following 092-315, 092-660, 092-668.
    Upon inspection of the drum unit I found the (K) Black toner exit hole packed to the brim with toner
    and piling up on top of the back of the drum. I looked at the other drum units (M,C,Y) and found no excess toner.
    After vacuuming and cleaning the (K) Black drum unit area as bets as possible, and resetting NVRAM
    752-368 (was at 1 reset to zero) 752-372 (was at 3 reset to zero).
    Turned machine off (Top Power Button first then inside cover button next) Machine upon starting up printed several blank pages, then there was a metal clink sound and the 092-315 system error redisplayed itself on main screen.
    I have determined that one of the following is at fault:
    Main Drive Assembly – 007K16710
    Dispense Motor -127K61161
    Developer Clutch – 121K46371
    Drum Drive Motor – 127K61161
    Since this a time and materials call, was just looking for opinions on which one of the above would
    be most likely to try first?
    All help is appreciated, and thanks in advance
  • Mukasa
    • May 2015
    • 178
    Re: Advice Needed: Workcentre 7120 / System Error 092-315 on main display
    Hello Can you check the following.
    Check the following:
    • The connection between the MCU PWB P/J411 and the CRUM Reader (K) P/J123 for open circuit, short circuit, and poor contact
    • The connection terminals between the Drum Cartridge (K) CRUM PWB and the CRUM Reader (K) for damage and foreign substances
    • The Toner Dispense Motor (C,K) for revolution failure: Component Control [093-004] ( PL 5.1)
    • The Drum/IBT Drive Motor for revolution failure: Component Control [042-001] ( PL 3.2)
    • The Main Drive Motor for revolution failure: Component Control [042-006] ( PL 3.3)
    • The Dev K Clutch for failure: Component Control [042-010] ( PL 3.3)
    • The path from Toner Cartridge (K) to Developer (K) for toner blockage
    • The Developer (K) for internal toner blockage
    • The Toner Cartridge (K) for internal toner blockage
    If no problems are found, replace the following parts in sequence:
    • rockdude
      • Feb 2011
      • 257
      Hi
      Thanks for the reply, but I already fixed it.
      Turned out replacing the Main Drive assembly was the answer.
      (and a through vacummingand cleaning)
      Gears were caked with toner, and clutch was sticking due to toner contamination.
      (Sorry I gave wrong part number for Main Drive. It was actually #007K16690)
      Thanks again for your input.
