xerox workcentre 7132 with ERR code 010-330
  • na5_70
    • Mar 2008
    • 8
    Hi , I have workcentre 7132 with err 010- 330
    How I can to fix this ERR plz,
    regard,
  • mmru4real
    • Aug 2008
    • 67
    regard,
    Hope this Helps
    010-330 Fuser Motor Failure RAP
    BSD-ON:4.1B
    The Fuser Motor is not rotating at the specified speed.
    Initial Actions
    Procedure
    Close the LH Cover and the Front Cover.
    Execute Component Control [010-001 Fuser Motor ON].
    The Fuser Motor can be heard.
    YN
    Go to the OF 4 (Fuser Drive Assy RAP).
    Check the installation of the Fuser Unit (PL 1.1).
    The Fuser Drive Assembly is installed correctly.
    YN
    Install the Main Drive Assembly correctly.
    Check the wire between P/J412 and P/J226 for an open circuit or a short circuit (BSD 4.1A).
    The wires are conducting without an open circuit or a short circuit.
    YN
    Repair the open circuit or short circuit.
    Manually rotate the Fuser Motor rotor.
    It rotates smoothly.
    YN
    Check for foreign substances that are interfering with operation or installation failure.
    Foreign substances or installation failure are found.
    YN
    Replace the Fuser Unit (PL 7.1).
    Remove the foreign substances that are interfering with operation and correct the installation failure.
    Replace the Fuser Unit (PL 7.1) If the problem persists, replace the MCU PWB (PL 11.1).
    • ktxerox
      • Mar 2009
      • 229
      enter the diagnostic mode with hold the 0 key for 4 sec and then press the start key. 6789 is password go to nvm read write and reset the velue at nvm location 744- 004 to 0 .
