Fault code 091-311 Xerox 4110
  • michko87
    • Oct 2015
    • 7
    I can't boot the printer, stuck with fault code 091-311 CC cleaner motor fail
    What I did so far:
    1. Replaced drum unit
    2. Replaced CC cleaner position sensor 930W00111
    3. Replaced CC cleaner motor 127K037670
    4. Replaced IOT PWB that's connected to cc cleaner motor (connector P435)
    5. Replaced MCU PWB
    6. Replaced flexible print cables between IOT PWB and MCU PWB
    Problem still not solved, any suggestion are more than welcome.
    I looked for an open wire or poor contact on wires between cc cleaner motor and IOT PWB, found nothing.
    Maybe there is problem with voltage or resistance or whatever, I don't know, probably should call an eletrician to measure the values.
  • Dech
    • Aug 2014
    • 48
    Re: Fault code 091-311 Xerox 4110
    Hi
    Had same problem:
    Changed the AC power supply..
    problem solved..
    Part: 105E17761 AC UNIT (200v)
    • michko87
      • Oct 2015
      • 7
      Originally posted by Dech
      Hi
      Had same problem:
      problem solved..
      Thanks for replying.
      I'll try that.
      • michko87
        • Oct 2015
        • 7
        OK, I have changed the AC unit.
        No more 091-311, but now it's stuck on booting with fault code 116-353 (HDD Physical fail).
        I'm gonna look into that...
        • Dech
          • Aug 2014
          • 48
          Hi
          Go back and make sure you have not missed any plugs....
          • michko87
            • Oct 2015
            • 7
            I've checked everything, it's all connected, so maybe it's corrupted HDD.
            I've tried to initiate the HDD, but it won't let me, when I enter diagnostics that option is grayed out.
            • adriansto
              • 2369
              Press and hold Stop, Powersave and 4 during machine power ON.
              • michko87
                • Oct 2015
                • 7
                Still can't boot, but now fault code is 116-330.
                If HDD is dead, do I need PWS laptop to install all over again on new HDD?
                • adriansto
                  • 2369
                  No, only replace the hdd.
                  Be sure the 12 volts that power the hdd is ok.
                  • michko87
                    • Oct 2015
                    • 7
                    Checked the voltage, it's 12v.
                    So what do I need to do now regarding HDD replacement?
                    This bad one is hitachi ata with capacity of 41.1 gb, can I use hdd larger than 41.1 gb?
                    I would really appreciate if someone can write step by step instructions (do I need to save or backup anything, what software version to download, how to install)...
                    • Metehan
                      • Oct 2022
                      • 1
                      Makineyi 4 stop uyku modu tuşu ile açınız. Ekranda HDD initialization uyarısını gördükten sonra tuşları bırakınız. Sonrasında makine açılacaktır.
                      91-311 arızası için ilk olarak basitten gidilerek kontrol edilmesini tavsiye ederim. Drum unitesinin üzerindeki sensör kırılabiliyor.
