Xerox WC 6605/Phaser6600/ Dell 2660dn 092-671 "Reseat M Toner and M Drum" error
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Xerox WC 6605/Phaser6600/ Dell C2660dn/C2665dn 092-671 error code
    ErrorCode 092-671 "Reseat M Toner and M Drum" signifies:
    Magenta Patch Error/IOT could not recover toner density.
    Steps we already did:
    cleaned the ROS windows for each drum
    reseated the magenta drum and toner
    Cleaned the CTD Sensor
    replaced M toner cartridge
    replaced M drum (all 4 drums actually since they come in a kit)
    After replacing the magenta drum unit-----the error went away but came back again after only 2 days.
    Customer is using LD Products generic color toners.
    Based on the unit working for a couple days and how toner is supplied to the drums:
    Upper Dispenser Motor Assembly (PL5.1.1) drives the paddle in the Toner Cartridge and the auger of
    the Dispenser Assembly and feeds toner to the development section in the Imaging Unit
    Now suspect that Magenta toner is not supplied to the drum. Probable bad toner dispenser unit or auger not turning. The motor drives both Magenta and Yellow, so since the Yellow drum is not giving an error...........the motor is most probably fine and the dispenser unit for magenta has failed.
    Remarks/Comments appreciated. Thanks.
    • 22801
    Re: Xerox WC 6605/Phaser6600/ Dell 2660dn 092-671 "Reseat M Toner and M Drum" error
    my boss ( cheap ass ) pushed most of our customers to LD or Clover....
    I spent TOO much time chasing these pieces of shit.
    i know LD is touted as a 'good' cart.. don't believe it.
    are you supplying them or is customer?
    are they on a maintenance plan? if so.. void it.. you will waste time-gas-resources and hair if he continues this practice.
    • blazebusiness
      • 1250
      No maint agreement.......Customer is buying their own toner from LD Products ------------not from us. You and I both know that the generics are a huge savings but do not come without risk. Obviously oem is the way to go. It is certainly possible that the generic toner provoked this. Hard to know for sure.
        • 22801
        Get into toner supply to dev.
        More than likely its clogged..had this on 3. 6605's @ NCDOJ. THEY got really pissed and dropped us & LD as soon as I got machines running..
        The I got razzed from boss for talking shit about the toners he sold them.
        • blazebusiness
          • 1250
          By getting into toner supply for developer I assume you mean removing the:
          Disp Assy- M (Dispenser Assembly - M) part# 094K93422 and checking for blockage/clogs. Problem is it will be very labor intensive --customer probably won't want to pay that much for labor and a lot of stuff has to be removed (see below)
          Dispenser Assemblies Y, M, C, K
          PL5.1.4-7
          Note: The Dispenser Assemblies must be removed in order from the bottom, K, C, M, Y .
          1. Remove the Toner Cartridges Y, M, C, K. (page 4-37)
          2. Remove the Transfer Belt Assembly. (page 4-38)
          3. Remove the Imaging Units Y, M, C, K. (page 4-48)
          4. Remove the Upper Dispenser Motor Assembly. (page 4-27)
          5. Remove the Bypass Tray Frame Assembly. (page 4-65)
          6. Disengage the connector of the Dispenser Assembly K.
          7. Remove the three screws (silver, tapping, 8mm) that attach the Dispenser Assembly K and pull the
          Dispenser Assembly K to the front while pressing the lug on the left side inward with a screwdriver.
          8. Remove the two screws (silver, tapping, 8mm) that attach the Frame Duct (PL4.1.1) to the printer
          and remove the duct.
          9. Disengage the connectors connected to the Dispenser Assemblies in the order of C, M, and Y.
          Remove the three screws (silver, tapping, 8mm) that attach each Dispenser Assembly, and pull the
          Dispenser Assemblies to the front in the order of C, M, and Y while pressing the lug on the left side
          s6600-
          I'll probably just recommend an affordable replacement unit. Appreciate the time you spent responding. Thanks.
            • 22801
            PL5.1.4-7
            s6600-
            Yeah well.. WHEN did you ever see Xerox making it easy or cheap on any repair...?
            • Richard.Xerox
              • Jun 2015
              • 73
              Dispense assemblies only 60 minute job, no need to remove main drive (just 2 furthest screws to right so you can bend out the main drive a bit to remove bypass frame assembly), just need to make sure you re-seat them properly in the frame when you put dispensers back in. Long screwdriver helps.
              • svastarija
                • Dec 2019
                • 10
                Hi.
                I am having the same issues with Dell C2665dnf which is xerox 6605. My error is 092-673. I am going to give it try and disamble K Dispenser Assemblies. Very tempted to use air compressor and see if anything is stuck in black toner feeding tube.
                Found this video (link below) which at one point shows Dispenser Assemblies steps.
                YouTube
                  • 22801
                  Originally posted by svastarija
                  Hi.
                  YouTube
                  NO FUCKING COMPRESSED AIR!!! you will be cleaning up a BIG mess!
                  use a 3M copier tech VAC.
                  • svastarija
                    • Dec 2019
                    • 10
                    Update:
                    So in admin menu disable "Drum initialization" settings. And now I get new meesage The Black Drum Cartridge is not correctly installed. :091-921
                    I did try this as well with no luck..
                    YouTube
                    • svastarija
                      • Dec 2019
                      • 10
                      • ocular
                        • Dec 2019
                        • 6
                        svastarija - were you using generic or genuine toner? how are you going with getting the printer working again?
                        Is the problem of the ?blocked dispenser assembly feeder specific to generic and genuine toner usage?
                        • svastarija
                          • Dec 2019
                          • 10
                          Update 2:
                          After some inspection I did notice that drum chip plug pins are bent. Luckily the black drum connector in the last one in the row so I managed to take it without disabling printer. Long story shor I did manage to fix the connector plug (black). Guessing that was relating to 091-921 error.
                          Also, used shop vacuum and air compressor to clear black toner feeding tube. So far so good, no error at this time. This was a two-person job since feeding tubes have latches on both sides.
                          Regards
                          • svastarija
                            • Dec 2019
                            • 10
                            Yes, I am using generic replacment toners.
                              • 22801
                              generics have never worked properly in the Xerox lines.. esp in the 6600/6605 I have 15 in the field in one building... they went with generics all sorts of issues popped up. I have been servicing Xerox since 1997.
                              the boss fired NCSD because they refused to drop the generics ...
