Xerox Docucolor 252 Network scanning icon not active
  • maikel safwt
    • Nov 2014
    • 58
    Xerox Docucolor 252 Network scanning icon not active with fairy system
    Many thanks
    • 22801
    Re: Xerox Docucolor 252 Network scanning icon not active
    Originally posted by maikel safwt
    [ATTACH=CONFIG]43021[/ATTACH]
    Many thanks
    reload firmware with altboot procedure to begin with
    • xcopytech
      • Aug 2006
      • 1783
      You can not altboot xerox dc252.
      Reload fiery software.
        • 22801
        my bad.. didn't think Fiery not fairy
        • maikel safwt
          • Nov 2014
          • 58
          Sorry for my language,
          How can i reload the software
          Many thanks
            • 22801
            Sorry for my language, How can i reload the software Many thanks
            that is covered in the SM
            • maikel safwt
              • Nov 2014
              • 58
              Unfortunately i didn't have the service manual, I tried to search for it but i didn't found it
              • InterfaceP
                • Jun 2013
                • 489
                You need the software and the USB Prep-Tool, both of which I have on my server. Message me if you would like them.
                • Tecnico_Xerox
                  • Jan 2019
                  • 54
                  Many thanks
                  Hi.
                  The fiery has 2 network ports, one is for the local network and the other is for the scanner. Check that the network cable coming from the port "Scanner" of the fiery is connected to the network port of the printer, the cable that is occupied is cross network.
                  good luck.
                  • Vinod
                    I want this software and USB Prep- Tool, Can u help me
                    • ScoobyDoo
                      • Jul 2020
                      • 2
                      I've got a Docucolor 250 with similar issue, been working fine and now the 'Network Scanning' is greyed out? Rebooted several times, checked cables, but still doesn't come up, now not able to print to it or connect the CWS. No idea if I've got any Fiery software or what to do with it if I can find any? Desperate for solution to get it talking to the network and printing again. Anyone got a solution?
