Versalink c405 admin password
  • deputydogg
    • Nov 2015
    • 172
    I have a customer that has one and their I.T. guy says the admin password needs to be reset ?
    Will someone direct me on this, other than calling xerox.
    Thanks,
    Dave
  • adriansto
    • 2369
    Re: Versalink c405 admin password
    Thanks,
    Dave
    One method is to reset the admin passwd using 12 digit reset code.
    This code is generated by special software using machine serial number and total meter.
    Other method is to use special boot mode - nvram init mode.
    This will clear all machine settings so it should be use with caution.
    • deputydogg
      • Nov 2015
      • 172
      So will the customer have to find a authorized xerox service that has "special software" or is this something I can do ?
      Thanks,
      Dave
      • adriansto
        • 2369
        Thanks,
        Dave
        I can generate the reset code for you.
        Send me mail = stoadis@gmail.com
        • deputydogg
          • Nov 2015
          • 172
          Done.
          • toconnor602
            I am having the same issue with my versalink c405. is this something you could assist me with? I have been searching for hours on how to reset this machine back to the factory defaults.
            • adriansto
              • 2369
              The reset code get back the default admin password, not reset machine to factory default.
              • pixelbaker
                Same issue here. IT consultant for a non-profit. Cannot for the life of me get the admin password reset to update their SMTP settings. A factory reset or just admin pass reset would be awesome. All info I've found online says I need a Xerox technician to come out for ~$350, so I'd really like to avoid that.
                • adriansto
                  • 2369
                  Send me mail stoadis@gmail.com
                  • Helicase
                    I have my Versalink C405DN since 2,5 years. It seems that I actually forgot my admin password too.
                    Is there any chance I could ask you for that code too?
                    Regards, Chris
                    • adriansto
                      • 2369
                      Regards, Chris
                      Send me mail with complete machine serial number and total impressions counter.
                      • aarrindell
                        Hi,
                        I just received a new versalink c405, we were having some issues with it so we factory reset it. We had never changed the default password prior to resetting. Now when setting it back up, it states that the printer is using the default password, but whenever i enter 1111, it states the password is incorrect. Is this something you can assist with? Possibly resetting to see if that solves the issue?
                        • adriansto
                          • 2369
                          Send me mail = stoadis@gmail.com and attach printer configuration report.
                          • joenitro
                            • Jul 2019
                            • 1
                            Originally posted by aarrindell
                            Hi,
                            Might be worth trying the serial number of the device as the default password?
                            There was an update recently to newer machines changing to this from now on for increased security
                            • Jasonjo
                              I recently bought one of the printers brand new and liked it so much I bought a second one for home from ebay. Problem is that it has a non compatible fixed IP address and someone has changed the default admin password. Could someone help me reset the password? Its a 2017 model.
