fault 094-322 xerox 242
  • creative-proto
    • Oct 2019
    • 4
    Please help .. I am beyond frustrated with this.
    I continue to receive the error ... any hints on how to correct this?
    • 22801
    Re: fault 094-322 xerox 242
    a little ore info is needed:
    when does the error appear?
    boot?
    warm up
    trying to print?
    did you even search CTN for like issues?
    Error Code Doc250 error code 094-322
    • creative-proto
      • Oct 2019
      • 4
      it occurs when trying to print most times, and some times upon boot up.
      I have removed the tray and reconnected all the wires, and cleansed transfer belts and gears.
      i have turned on with out the firey on and booted up with no faults
        • 22801
        It could be firey related..
        Not knowing your skills, I would be inclined to pass on this DIY and hire local.
        • InterfaceP
          • Jun 2013
          • 489
          2nd BTR retract fail
          Really easy to fix, first order an new 2nd BTR
          In the mean time open the front door and locate the 2nd BTR. On the front side of the plastic cover for the drawer, look for a small opening with a black and yellow disk behind it. It has a place to insert a Flathead screwdriver, rotate it clockwise several times. now power off and on the printer, It should go away for the time. But once again order another 2nd BTR
          Good luck
          • InterfaceP
            • Jun 2013
            • 489
            This has absolutely nothing to do with the Fiery.
