SCAN SMB XEROX 7120
  • spann
    • May 2020
    • 2
    SCAN SMB XEROX 7120
    Hello everybody
    I need your help please because I have just purchased a xerox 7120 photocopier but
    2.JPG1.JPGunfortunately I cannot configure the SCAN SMB and I still have the error code 027-516
  • copytech200X
    • 264
    Re: SCAN SMB XEROX 7120
    027-516: Server Connection Error. This code indicates the scan transfer was unable to locate the shared folder on the PC workstation. This code can be generated by the following: - The network cable is unplugged. - The 'Hostname' or 'IPv4 Address' was entered incorrectly in the address book
    above is first things you need to check otherwise sharing permissions on network sharing and look for advance sharing make sure turn off password protected sharing .
    • spann
      • May 2020
      • 2
      Hello
      thanks to you i will check all his
