Xerox versant 80 Toner
  • mshabban
    • Jan 2017
    • 101
    Hello guys ,am having a challenge here in East Africa with these toner suppliers ,they have two different types of branded box both for xerox versant 80,one box has a seal for on top of the box and the other box has its seal on the side of the box ,the boxes look totally different ,am wondering if xerox can really have two different toner boxes .
  • Exok
    • Jun 2011
    • 750
    Re: Xerox versant 80 Toner
    I don't know about the boxes but just about all xerox machines have 2 types of toner depending on the billing status of the machine. 1 is called Metered toner (if you purchase your toner directly from xerox) or Non-Metered toner (you purchase toner from a non xerox vendor). Depending on how the machine is set up you need to purchase the correct toner or you will get a toner incompatibility error.
    • jhalfhide
      • Apr 2015
      • 451
      Sold toner (non metered) will work in both types of machine. Metered will only work on metered machines.
      Sent from my LYA-L09 using Tapatalk
      • Exok
        • Jun 2011
        • 750
        And if you are buying toner from an individual seller such as from Ebay, you really don't know what you are getting. You may have a machine that uses "sold" or Non Metered and buying from a guy who has a Xerox contract and is sitting on a stock pile of extra "metered" toner. If your machine was set up for Metered toner and you use Non-metered toner, ,now it's lock as Non-metered. If you try to use Metered again, you get an error.
        • Caffeine
          • 389
          Xerox does change their packaging fairly frequently, especially when toner is sourced from Japan (when a machine is new) and then from domestic sources (after a machine is more established in the field). The Fuji Xerox (Japan) packaging is very different (and much nicer! haha) than the Xerox packaging.
          If you wanted to post pictures of both box styles, we could give you a better idea if they are legitimate or not.
          • fugglefeet
            • Jun 2020
            • 34
            Hi all,
            I hope the attached PDF will be of assistance with the part numbers for the various toners.
            fugglefeet
