Altalink C8055 empties developers
  • Detonation
    • Feb 2010
    • 389
    I have an Altalink C8055 that is emptying all developer housings. The developer housings themselves seem ok, with all gears rotating freely and not visible damage. So do the drums. I have refilled the developer housings, checked ATC sensor setup, calibrated developers, and this all went well. But the machine spits out copies without random color smears, and empties the developers right away. In attached image you can see the toner buildup on the drum after just a few prints.
    I have checked ITB, developer and drum motors from component control, and they all seem to be functioning just fine. What could be the issue?
  • jhalfhide
    • Apr 2015
    • 451
    Re: Altalink C8055 empties developers
    Usually this is a Dev bias issue. On this model, it's one board for all colours so I'd change the Developer HVPS
    Sent from my LYA-L09 using Tapatalk
    • Detonation
      • Feb 2010
      • 389
      • jhalfhide
        • Apr 2015
        • 451
        Both completely different unfortunately.
        • Detonation
          • Feb 2010
          • 389
          I know I sound like a newbie here, but as mentioned I still have to get my hands on the edoc for this model. Where is the dev HVPS located? I know where it is in the 7855, but when I peak in the C8055 there is no board in this location. There is a small board attached to the bottom frame, is that it?
          EDIT found it. Will post back on results.
          • Detonation
            • Feb 2010
            • 389
            • jhalfhide
              • Apr 2015
              • 451
              This looks like the culprit then
              • Detonation
                • Feb 2010
                • 389
                Thanks, will try tomorrow!
                • Detonation
                  • Feb 2010
                  • 389
                  I've replaced MCU-PF PWB, MDM PWB, and refilled the developers - again, on the booting the machine it just empties the complete contents of the developer housings within a few seconds. Please see attached pictures. This is so incredibly frustrating. So much time and developer down the drain. Should I give up on this machine? Would be such a shame.
                  • Detonation
                    • Feb 2010
                    • 389
                    Small bump as I still have this problem and really need to get it solved.
                    • Detonation
                      • Feb 2010
                      • 389
                      Called Xerox, they had a tech come by. He thought one of the drums was bad and causing a short, but this wasn't the case. He replaced both the HVPS as well as the developer HVPS and that solved it. Since I already tried a developer HVPS from a different machine the regular HVPS must have been te problem.
                      • Caffeine
                        • 389
                        Thanks for coming back and letting us know the resolution. Helps for the future.
