Altalink C8170 , app enablement on main screen
  • copytechman
    • Nov 2008
    • 926
    I have enabled the ID Card Copy app for the main screen but its not showing up.. Is there a magic trick? Latest firmware is installed.... also the internet fax and server fax buttons don't show up when the buttons/apps are enabled...
    I must be missing something.
    Thoughts?
    A!
    • 22801
    Re: Altalink C8170 , app enablement on main screen
    Thoughts?
    A!
    did you try updating the firmware ?
    • copytechman
      • Nov 2008
      • 926
      Yes that was the very first thing I tried after I saw that behavior, no change after installing latest firmware.
      Thoughts?
      Regards! A.
      • Detonation
        • Feb 2010
        • 391
        I have no experience with the C8170 just yet, but where did you enable it? Via the web interface? A screen shot would be helpful.
        • copytechman
          • Nov 2008
          • 926
          Yes via the web interface... .in fact by default the "app" was set to on or show.... but does not show on the copiers home screen... neither do internet fax or the other one (forget the name) they all do on the older model (c8045 for example) the set looks identical for the most part but the button just doesnt come on the op panel.... but that did make me think of one thing via the op panel... will check/try that and report back.
          Stay tuned.
          A.
            • 22801
            Stay tuned.
            A.
            try doing an ALTBOOT
            • copytechman
              • Nov 2008
              • 926
              Nope not needed... turns out... you have to add it to the screen via the customize function once logged in as admin via the op panel... you can then place the button... odd that they changed that from the prior generation device... was a bit of a head scratcher..... this applies to the internet fax function and others as well.
              • Detonation
                • Feb 2010
                • 391
                Glad you solved it and thanks for posting the solution.
                • copytechman
                  • Nov 2008
                  • 926
                  I believe that we are all techs together and the more we know the better!
                  regards!
                  a.
