Xerox Versant 80 180 2100 3100 tag 13
  • azehnali
    • Nov 2009
    • 679
    anybody know the part number for the bracket that holds the fly wheel ?
    also the gear that goes on the 1st BTR and goes into the fly wheel
    thanks
  • jhalfhide
    • Apr 2015
    • 451
    Re: Xerox Versant 80 180 2100 3100 tag 13
    Flywheel coupler - 822E27071
    Mounting Bracket - Not Spared
    Sent from my LYA-L09 using Tapatalk
    • azehnali
      • Nov 2009
      • 679
      thanks
      it does show on the parts book as not spared
      was hoping they came up with updates
      heard about a retrofit
      • Sn0wlink
        On-Site Engineer
        • 35
        Originally posted by azehnali
        thanks
        I believe there is a retrofit kit available for non tag 13 machines, But it does involve quite a bit of work and new front door to convert it over to tag 13.
        I think it was designed to fix some of the micro-banding and impact banding issues encountered on the earlier models, but putting the machine into skip pitch mode is another option.
        NVM Read/Write > 740 492 > enter 1 for enable or 0 for disable
        There's the tool the works, Then there's the tool that is Right!
        https://www.sn0wlink.com
        • azehnali
          • Nov 2009
          • 679
          So if I want to take the fly wheel off I enable it?
          • Sn0wlink
            On-Site Engineer
            • 35
            I would enable skip pitch if your running the machine and getting issues, yes. It will also fix the 2nd BTR streaking problems when running silk stocks.
            Please note this will greatly reduce the running speed of the machine.
            • azehnali
              • Nov 2009
              • 679
              dont you think its better to upgrade the software and nvms with the new update
              • Sn0wlink
                On-Site Engineer
                • 35
                I was suggesting that if you need to remove the flywheel (because of broken components) it is a good idea to run the machine in Skip Pitch mode to slow down the machine to a safe operating speed and remove the micro-banding issue that you may encounter. Updating the software is separate from the NVM Read/Write, the NVM Read/Write is primarily for engineers to change the machine running settings or for making adjustments.
                Usually a software update won't touch the NVM setting, but it is always recommended you make a backup to a USB drive first.
                Sorry for the confusion.
                • azehnali
                  • Nov 2009
                  • 679
                  thanks
                  • Tecnico_Xerox
                    • Jan 2019
                    • 54
                    822E27071, 822E27070, Back-Up Roll Drive Coupling, Xerox(R) V80 / V180, V2100 / V3100
