700i error 027-741
  • Wally181
    • May 2021
    • 8
    [Error Code] 700i error 027-741
    Hi All,
    I have a xerox 700i with integrated fiery machine was working fine then had a paper jam and needed to be restarted, now Command workstation can not find the server.
    Have checked all cables and connections and everything seems fine. Cannot ping the ip from my pc. The machine will also not print the start up page. All ip addresses are correct,.
    On error history print out 027-741 Job template server server connect fail.
    Can anyone advise a solution.
  • azehnali
    • Nov 2009
    • 679
    Re: 700i error 027-741
    what does the LED on the fiery indicate?
    • Wally181
      • May 2021
      • 8
      00
      • azehnali
        • Nov 2009
        • 679
        havent worked on the 700 in a long time
        they are antique
        I think that model when the fiery boots up there is an icon on the UI
        either Fiery logo or network scanning or something
        • copytech,mike
          CopyTech,MIKE
          • Jun 2014
          • 254
          they are antique
          I only worked on a few and they are notorious for refusing to boot up and come online. Unplug, plug in, power up and wait forever. Over and over until it comes online. Better to talk customer into getting something better.
          • Wally181
            • May 2021
            • 8
            It is my machine and other than this issue which it is the first time it has happened is printing without issues.
            • xcopytech
              • Aug 2006
              • 1783
              Reload fiery system software
              • Wally181
                • May 2021
                • 8
                Hi thanks for your input, I have 2 fiery server boxes and both are doing similar things, however I can now ping the fiery.
                when I go to web aplications on the 700 it comes back with a message (an error has occurred when communicating with the server) (-100)
                • xcopytech
                  • Aug 2006
                  • 1783
                  Do you have crossover cable between fiery and machine?
                  • Wally181
                    • May 2021
                    • 8
                    yes and have tried 3 different Ethernet cables
                    • xcopytech
                      • Aug 2006
                      • 1783
                      Cable must be a crossover.
                      If you can ping fiery ip address then you try to enter fiery ip address at any web browser to see can you open fiery web page.
                      • Wally181
                        • May 2021
                        • 8
                        Cross over cable is connected, can ping the machine from windows powershell but refuses to connect from web browser
                        • adriansto
                          • 2369
                          Windows firewall on your pc or antivirus firewall.
                          • Wally181
                            • May 2021
                            • 8
                            No, turned firewalls off and still no connection.
