Need help - Docucolor 242 - Setting up Scan to Email
  • jonmck
    • 23
    I have a Docucolor 242 and need help in setting up the scanner so that it will send the scanned images to an email address. I have tried several settings, but I am not having any luck. I can't find anything online about this either or in the manuals. Anyone have knowledge about setting this up?
    THANKS!
  • TechMate
    • Mar 2008
    • 285
    Sorry, but it's not a feature on this particular model
    • jonmck
      • 23
      Hi - the Doc 242 can scan to email or to FTP, etc....but I am just having issues with the settings. There is a spot in the scan template where you can put an email address to send the scanned image to.
      • TechMate
        • Mar 2008
        • 285
        If you say that it does, scan-to-email and scan-to-FTP are 2 different things. If it can scan-to-email, you need to have the proper SMTP/IP address entered and SMTP authentication details if required. If it can scan-to-FTP you need a SERVER address and a SHARE NAME to which your file will be scanned/ stored to. You also need FTP services running on the server you are scanning to and a username and password entered on your machine DC242...
        • jonmck
          • 23
          there is a space for smtp, etc., but I can't make the darn thing work. I am sure there are just some settings I am missing. I just wish there were some instructions online or somewhere that can walk me through this.
          • adriansto
            • 2369
            DocuColor 242 252 260 Online Support and Frequently Asked Questions (FAQ) | Xerox USA
            • jonmck
              • 23
              thanks - I have looked there before and could not find anything about setting up the scan to email or scan to computer.
              • XeroxTechBrazil
                • Aug 2008
                • 198
                Scan to File & FTP, Scan to Email
                I have four files, one is 8.7 MB, covering scan to file & FTP, and scan to email from Xerox DocuCentre and WorkCentre products.
                I think they are too big to attach here, but if you send me your email address I will forward them to you.
                Three are in French. But, there ARE lots of pictures of step by step screen shots that illustrate the setups.
                JorgeXcalak@live.com
                • TechMate
                  • Mar 2008
                  • 285
                  i think you are missing the whole point. What he wants is setting up scan function for a DOCUCOLOR model which is not in your list
                  • jonmck
                    • 23
                    • XeroxTechBrazil
                      • Aug 2008
                      • 198
                      DC242 Will Not Scan To File?
                      TechMate:
                      What you are saying is, the 242 will NOT scan to file like the 250 does?
                      • TechMate
                        • Mar 2008
                        • 285
                        click on the 3 dot-icon just beside the email entry area. Thats probably where some information are needed
                        • TechMate
                          • Mar 2008
                          • 285
                          TechMate:
                          Yes it can scan to file (sorry if you misunderstood)
                          • jonmck
                            • 23
                            Thanks - that opens the address book (which is empty)
                            • TechMate
                              • Mar 2008
                              • 285
                              Ok then. I've noticed there's a CONFIGURE tab. click on it and get into configure. I'm sure there's a part under PORT settings where TCP/IP and SMTP settings are located. Be sure you have the correct SUB NET, GATEWAY, and SMTP server address. Don't forget to SAVE and reboot after the change...
