Xerox Versant 180
  • azehnali
    • Nov 2009
    • 679
    Xerox Versant 180
    anyone know if the EX-180 running windows 8 can be upgraded to windows 10 ?
  • jhalfhide
    • Apr 2015
    • 451
    Re: Xerox Versant 180
    It's ridiculously expensive. The upgrade option is in the dealer price list, and it's a couple of thousand pounds.
    Quote a customer and they soon go right off the idea.
    Sent from my LYA-L09 using Tapatalk
    • azehnali
      • Nov 2009
      • 679
      thanks
      • xcopytech
        • Aug 2006
        • 1783
        Ex180 V1.2 software is win10.
        • azehnali
          • Nov 2009
          • 679
          great
          how can I preserve the impose and compose license and the graphics package
          • xcopytech
            • Aug 2006
            • 1783
            All licenses which you have on v1.0 will stay.
            Licenses stay on fiwry even if you replace HDD
            • azehnali
              • Nov 2009
              • 679
              I have upgraded the command workstation in the past on the versant 2100 and the licenses did not stay
              Had to call fiery to resolve and they are not the best for getting any kind of help
              • xcopytech
                • Aug 2006
                • 1783
                Never had any problem with licenses on fiery.
                You can upgrade ex180 fiery on windows 10 without any problems.
                • azehnali
                  • Nov 2009
                  • 679
                  how do you retrieve the licenses after you upgrade?
                  • xcopytech
                    • Aug 2006
                    • 1783
                    Do not need to retrieve license.
                    Licenses are not installed on HDD so you can install new OS or replace HDD without problem
                    • azehnali
                      • Nov 2009
                      • 679
                      do you know where its installed?
                      on the 2100 that I upgraded the command workstation it still says I need the graphics license
                      thanks
                      • xcopytech
                        • Aug 2006
                        • 1783
                        It is on security chip
                        • jhalfhide
                          • Apr 2015
                          • 451
                          thanks
                          Fiery Command Workstation Version 6.6 and above now require a license key and will not work with the old physical dongles.
                          Downgrade to 6.5 and the old licenses work again
                          • azehnali
                            • Nov 2009
                            • 679
                            license key as in the 16 digit code that has been around for the last 7 years?
