Toner ea xerox 550
  • croma
    • Oct 2014
    • 87
    Toner ea xerox 550
    Can we put toner ea in 550? Someone has tried and can tell me what happened.
  • VirtualToner
    • Aug 2021
    • 1
    Re: Toner ea xerox 550
    From what I hear, you can put toner in any machine if you push hard enough...
    You can use DC 250 and 700 Toner in a Xerox 550, but you will need to change the End Cap and Chip.. We use 700 toner in our 550 as it's easier to get hold of.. I'm unsure what EA Toner is.
    Xerox toners have Chips and the Machine reads those to tell if that toner is compatible or not.. Shoving any old toner in won't have the right chip and won't work!
    • croma
      • Oct 2014
      • 87
      I asked this question because from a 700 I got the development block and to my surprise it works well. If there was a way to reset the chips, even if I don't understand how they work, if the printer writes over the chips or just reads them.
      • azehnali
        • Nov 2009
        • 679
        700 and 550 toner is the same
        • Caffeine
          • 389
          The 550 is EA-Eco, but you can use EA in it, for the most part. You might have some fusing issues on heavier paper that you wouldn't have with EA-Eco, but you can just increase the paper weight on the machine or turn on gloss mode to slow it down and it will be fine.
          For most standard papers, especially after the machine has warmed up and printed a while, you should be fine. So if you print long runs, no problem. The fuser gets extra hot while it is running and that is the extra heat you need.
          If you print lots of short jobs, and then printer goes back to sleep again between, maybe don't do it. The fuser is coldest the first few prints after turning on or waking up. The EA-Eco toner it is expecting works fine, the EA might (MIGHT, not WILL) flake off.
          550 and 700 use the same toner. Different cartridges (handle and chip are different), but same toner in them. Both are EA-Eco. You can't repurpose the chips from one to the other. You have to buy replacements.
          The developer material and developer assemblies for the 500 and 700 are interchangeable.
          • croma
            • Oct 2014
            • 87
            Do you know how chips work? How does the printer recognize them? Why can't I transfer chips from one printer to another?
            • Caffeine
              • 389
              They work the same as pretty much all printer "life" chips work. These particular ones are RFID.
              You can of course transfer them from one printer to another, if the two printers both use the same toner cartridge part number. A 550->560 or 550->C70, for example.
              Obviously you can't use the chip on the wrong printer, like a 550->700. Regardless of whether the actual toner powder is the same (it is) their toner's part numbers are different. So of course the chip won't work.
              • croma
                • Oct 2014
                • 87
                ok, obviously the chips work for the printer they were created for, what I mean is because once used they cannot be passed on to another identical printer.
                • Caffeine
                  • 389
                  • croma
                    • Oct 2014
                    • 87
                    Thanks to everyone for the exhaustive explanations, to date I tell you that on the 550 I put the development group of a toilet 7755 + toner of the 700 and I had no problems whatsoever. when I find a cheap chip reset I'll be on top
