Xerox J75 Printer drivers
  • mshabban
    • Jan 2017
    • 101
  • xcopytech
    • Aug 2006
    • 1783
    Re: Xerox J75 Printer drivers
    J75 do not have built in controller.
    You must have fiery if you want to print
    • mshabban
      • Jan 2017
      • 101
      Thanks mate , truly appreciate, but now the problem is my fiery has no display, all fans are running fine and when you remove the Ram , the fiery beeps , so I wonder what could be the issue as it just happened of a sadden, any heir will be appreciated.
      • xcopytech
        • Aug 2006
        • 1783
        Have you tried to remove bios battery for a couple of minutes.
        • InterfaceP
          • Jun 2013
          • 489
          It beeps because the RAM in missing. Check the LED display on the side, when working properly it should read "00" if it has another # post it and I will tell you what the issue is.
