Hello, this is my first message at the forum.
I am the owner of a printshop in Greece and I have a Xerox 560.
I have a technical problem that i can't figure out.
The problem is the same repeating white lines in a distance of about 3cm in all colors.
I have changed Belt, Belt Blade, Drums, Developers and 2nd BTR.
Also jammed the printer and checked if the lines appear on the printout on the belt and they were there so any parts after belt are probably out of blame.
Also cleaned 1st BTR cylinders.
I don't know what else to do.
I would really appreciate any kind of help.
In order to have a better understanding I am uploading a magenta and cyan printouts, at 60% color.
Thank you very much in advance and I will be expecting for any kind of help or feedback.
Best regards,
Stelios
Best regards,
Stelios
