Xerox D136 error 093-311
  • fatfingers73
    • Feb 2013
    • 219
    [Error Code] Xerox D136 error 093-311
    Hi all,
    I'm after some advice please.
    Replaced dispense assembly. Reset code to 0 (762-130), but fault comes back instantly.
    In supplies under status everything is blank? I've never had this before.
    Tried all eureka tips but I'm now stuck.
    Any advice would be great.
    Thank you
  • adriansto
    • 2369
    Re: Xerox D136 error 093-311
    Did you seen this bulletin = 1436702
    • fatfingers73
      • Feb 2013
      • 219
      I did yes. Going to order CRUM assy and MCU.
      I was hoping someone has seen the fault where supplies status was black.
      I've tried another LVPS and IOT PWB from another machine but with no juy.
      Hopefully MCU will sort it.
      Thanks for you reply.
      • nikolai.aleksie
        • Feb 2016
        • 177
        Originally posted by fatfingers73
        Hi all,
        Thank you
        Check this out:
        Xerox 4110 style (4110, 4112, or D95 families) - Fault Code 093-311: Toner Dispense Problems
        • fatfingers73
          • Feb 2013
          • 219
          Thanks, all that's been replaced
          • webfoot
            • Jan 2013
            • 4
            Was this ever resolved? We have a D95 doing the same thing. Replaced every related part and still having the problem.
            • fatfingers73
              • Feb 2013
              • 219
              In my case the client fitted the wrong dispense assembly.
              He fitted a d95 assembly to a d136.
              • irdicheku
                • Aug 2019
                • 17
                Good day fellows. My D95 also have the same problem. I changed a brand new dispenser and only lasts for one week. Everything this problem appears basically I opened the dispenser and there will be be toner clumped and it will fill on one side only. Is it my toner ( which is OEM I assume) causes this never-ending issues for two months now. Any ideas and suggestions is greatly appreciated. Thanks.
                Sent from my SM-A536E using Tapatalk
