I have a WC 7535 giving a "Scanner Error" fault code. There are also 362 errors in the fault history. You can print to the machine just can't scan anything. The scanner moves at start up and finds home position but the lamp does not come on. So far I have replaced the IIT PWB assembly the LED lamp and the ribbon cable running from the lamp to the IIT assembly. Tech support hasn't been much help. Anybody seen this before and come up with a fix? Thanks in advance.
Xerox WC 7535
