Xerox DocuColor 240 won't boot
  • martys39
    • Feb 2022
    • 11
    Hello,
    we have a problem with Xerox DocuColor 240. Printer not starting after running all day..
    When turning it on, loading progress bar loads up to half and stop. Because printer won't boot I can't get error code...
    IMG_20220209_122108_resized_20220209_122227849.JPGIMG_20220209_122215_resized_20220209_122228793.JPG
    Changed:
    ram's
    ide hdd
    low voltage Power Supply Unit
    all 3v batteries are good.
    When I pressing ENERGY SAVER, STOP, AND 4 (or 6) and turn on the printer, I get DOWNLOAD MODE, but I can't find firmware for this printer...
    Any help or direction would be appreciated.
  • adriansto
    • 2369
    Re: Xerox DocuColor 240 won't boot
    Originally posted by martys39
    Hello,
    [ATTACH=CONFIG]51991[/ATTACH][ATTACH=CONFIG]51992[/ATTACH]
    Changed:
    ram's
    ide hdd
    The copier stop at second segment from five boot segments. Can be:
    -ess memory or page sytem memory. Can try PowerSave+Stop+3 = nvm init
    - reseat the iit cable for bad electric contacts.
    -hdd with cable or you can try forced hdd format.
    - connection between ESS and MCU or bad MCU
    Probably you need pws diagnostic tool software to connect to machine and read the error code.
    I hope you have service manual for this copier.
    • xcopytech
      • Aug 2006
      • 1783
      Perform long boot diagnostic mode to get error code
      • martys39
        • Feb 2022
        • 11
        How to perform this mode?
        • xcopytech
          • Aug 2006
          • 1783
          Hold power save and start and power on machine.
          Hold it until get message on screen
          • martys39
            • Feb 2022
            • 11
            Thanks, I will try it tomorrow.
            • martys39
              • Feb 2022
              • 11
              I get this message: PLEASE REBOOT 116-317
              • xcopytech
                • Aug 2006
                • 1783
                Error is for MF rom on ESS pwb.
                Also can be bad one memory module (512mb)
                If you tried with new memory then try with MF ROM
                • martys39
                  • Feb 2022
                  • 11
                  I tried extract and re-insert the MF ROM.. I need to replace it?
                  Can I re-flash it if it bad, because I don't have another MF ROM?
                  Can ESS be dead?
                  • xcopytech
                    • Aug 2006
                    • 1783
                    If you have xerox pws and software for dc240 you can try to download software.
                    Good idea is to start with memory and mf rom.
                    Then you can try ess pwb
                    • martys39
                      • Feb 2022
                      • 11
                      I have xerox pws for cd240/250 v1, but I'm not sure if I have a good firmware for download mode.. Do You know where I can get firmware for dc240?
                      If nothing happens with memory and mf rom how much chance of a bad ess pwb..?
                      • xcopytech
                        • Aug 2006
                        • 1783
                        Do you know what software you have for xerox dc240?
                        Latest one is 1.231.16
                        • martys39
                          • Feb 2022
                          • 11
                          I don't know if that's it, but my versions are:
                          DADF ADF.bin 11.2.3
                          Controller E+ Nordic Control.bin 1.230.5
                          Controller EFIGS Controller.bin 1.210.6
                          Finisher C Finisher.bin 5.12.0
                          IIT IISS.bin 11.42.2
                          IIT Option IISS-Extension.bin 12.0.0
                          IOT IOT.bin 5.27.0
                          PWS Diagnostic Tool v1.0.0
                          PWS Framework v1.22.1
                          • xcopytech
                            • Aug 2006
                            • 1783
                            Do you know how to download software to dc240
                            • martys39
                              • Feb 2022
                              • 11
                              Noo, I dont know how to download newest software to dc240... Can You help me..?
                              I know how to download software to printer..
