Versalink C400DN admin password?
  • copiertec
    • Jan 2016
    • 2184
    I have a Versalink C400DN that I am trying to access via the admin page to change the IP. I have tried at the control panel, Admin, admin, 1111 and the serial #, none seem to work. Any suggestions, I am unable to access the webpage due to different IP octets and am trying to change the IP.
  • shinchan
    • May 2011
    • 193
    Re: Versalink C400DN admin password?
    try
    username 11111
    password x-admin
    • adriansto
      • 2369
      You need admin reset code. For generate the code must know machine serial number and total impressions counter.
      Send me mail with these = stoadis@gmail.com
      • thomfish
        • Jul 2014
        • 101
        You can change your router settings to get access via webpage and then send reset file to reset admin password. If not you can try send reset file via usb cable.
        • copiertec
          • Jan 2016
          • 2184
          Originally posted by shinchan
          try
          username 11111
          password x-admin
          thanks but it did not work
          • Jack79
            • Jul 2014
            • 312
            These details are not for your machine. If admin password was changed you can reset it by sending reset file to your printer. This file includes reset code. Machine serial number and total impressions are required.
            • Ricardo_Reis
              • 13
              Hey guys,
              Default admin password is: 1111 or serial number in capital letters.
              If that doesn't work, follow the procedure to reset the password on Versalink...
              Reset admin versalink: 302 Moved
