AltBoot problem - Unable to decrypt DLM
  • pdy-pt
    • Mar 2018
    • 58
    I replaced the hard drive on a Xerox AltaLink C8055 with a new one. However, when I AltBoot, I always get the error "Unable to decrypt DLM. Perform Special Altboot to upgrade the device" (see photo).
    Does anyone of you know the error and can help me?
    I have already tried several things:
    - Different USB sticks
    - FAT and FAT32
    - Different DLM firmware versions (unzipped)
    - Different (new) hard disks
  • xcopytech
    • Aug 2006
    • 1783
    Re: AltBoot problem - Unable to decrypt DLM
    You need special altboot software and 2 special altboot files
    • adriansto
      • 2369
      - FAT and FAT32
      [ATTACH=CONFIG]58136[/ATTACH][ATTACH=CONFIG]58137[/ATTACH]
      Files for Altboot are 400 Mb size. 200Mb file size is for upgrade only.
      • pdy-pt
        • Mar 2018
        • 58
        So did this procedure change from WC 78xx to AL C80xx?
        Where can these files be found?
        • adriansto
          • 2369
          What version ?
          • pdy-pt
            • Mar 2018
            • 58
            Best would be the newest firmware version. Did this procedure change? In the service manual it seems to be the same.
            • adriansto
              • 2369
              I have this file:
              SPECIAL ALTBOOT_Instructions for remediating the 316-720 error and the necessary files.
              • xcopytech
                • Aug 2006
                • 1783
                If you replace hdd then you need full software dlm file, about 500mb.
                Procedure is the same.
                If you replace hdd and sd card ar same time you need two more special files at USB so mochine can decompress dlm file
                • pdy-pt
                  • Mar 2018
                  • 58
                  Is this the file needed?
                  • xcopytech
                    • Aug 2006
                    • 1783
                    No
                    For special usb altboot you need
                    Swup_usb
                    Swup_usb.C8045_55
                    And dlm file with size about 500mb
                    • adriansto
                      • 2369
                      No
                      Swup_usb
                      Swup_usb.C8045_55
                      Something like this:
                      • big mike
                        • Sep 2012
                        • 140
                        When attaching the pws to the copier, are there two cords needed, a special one with a 4 pin connector?
                        • xcopytech
                          • Aug 2006
                          • 1783
                          You can do a special altboot from usb do not need pws
                          • adriansto
                            • 2369
                            As I know have 5 pins , usb serial ,and one of them is marked as GND.
                            The other is crossover cable. But there are anothers 2 files for pws altboot.
                            • kopycinskiadrian
                              • May 2021
                              • 2
                              Hello,
                              I have the same problem in Altalink B8055. The device prompts for special altboot procedure after hard disk replacement but I haven't any access to necessery files. Could you share special altboot procedure/files with me?
                              My e-mail address: kopycinskiadrian@gmail.com
