Versalink C405 - admin password ??
  • kuby
    • Oct 2007
    • 1370
    Tried to login to the admin using the default '1111' and that does not work but says 'Failed login attempt limit has been reached'. So I am guessing someone has already tried and locked it up. Am trying to login remotely so am not at the machine, it is about an hour away. Customer wanted to see it we could setup the scan to folder for them. Would restarting the machine reset the attempts?
  • CopierGuy7
    • Aug 2022
    • 8
    Re: Versalink C405 - admin password ??
    Yes, Restarting the machine should allow you to try again. The password will most likely be the serial number if it is not 1111. Hope this helps!
    • kuby
      • Oct 2007
      • 1370
      Yes restarting it allowed me to retry the password again. Not 1111, 6789, serial number ?
      • Rusty.Harris
        • Jan 2021
        • 605
        Unless someone changed it, it SHOULD be the serial number of the machine
        something like, 9HBxxxxxx or similar.
        • copier tech
          • 8095
          I had the same issue last week.
          Is is possible to reset the device admin password back to default ?
          • Jack79
            • Jul 2014
            • 312
            To reset admin password you need to send special reset file to the machine.
            • kuby
              • Oct 2007
              • 1370
              And how do I obtain this file? Is there a link to get it?
              • xcopytech
                • Aug 2006
                • 1783
                You will need admin password reset tool.
                Then tool will create 12 digit reset code from printer serial number and total counter.
                Then you will create reset.pjl file and with directprint.exe send it to printer
                • kuby
                  • Oct 2007
                  • 1370
                  Where do I get this tool and how much is it?
                  • adriansto
                    • 2369
                    Send me mail = stoadis@gmail.com with printer serial number and total impressions counter.
                    • Jack79
                      • Jul 2014
                      • 312
                      • xcopytech
                        • Aug 2006
                        • 1783
                        Send me mail at xcopytech@gmail.com and I will send you file and instructions for free.
