AltaLink C8130 refusing to altboot or software upgrade
  • Detonation
    • Feb 2010
    • 391
    I have a AltaLink C8130 running 114 software which is running fine, but refusing any sort of software upgrade or Altboot.
    • USB port are enabled
    • software upgrade is set to allowed
    • I was able to install pre-patch 746306v4.dlm and it shows appended to the 114 software revision
    • when I upgrade via the web interface the file is accepted, but it's just like the machine ignores it. It shows as 'completed' in jobs, but the machine doesn't seem to process.
    • I have tried this with 119 and 120 software upgrade files
    • when I try to Altboot the machine over USB, it just dead cycles and keeps rebooting. I have full Altboot files for 2 kinds of 119 software
    • when I try Special Altboot over USB, the exact same thing happens.
    I have not yet tried
    • LDRPC recovery patch: it shouldn't be needed from 114 software on if I'm correct? I will, regardless, try after the weekend
    Any suggestions are appreciated.
  • adriansto
    • 2369
    Re: AltaLink C8130 refusing to altboot or software upgrade
    • when I try Special Altboot over USB, the exact same thing .....
    Special altboot is different from each software level. What special altboot files did you tried?
    You can remove hdd/ssd clean all partitions ( format hdd ), put the hdd back and try with with special altboot for software version 119.xxx or 120.xxx.
    If this dont works the last method is to use pws altboot.
    • Detonation
      • Feb 2010
      • 391
      I tried special Altboot with version 119.009.023.13000. As I cannot perform PWS altboot, I am hesitant to format HDD. If it doesn't work, I am stuck without a working machine.
      • adriansto
        • 2369
        If machine work as it should then your usb stick not works properly or the machine usb ports are disabled.
        Did you tried all machine's ports?
        Can you print configuration report and send it to me?
        • Detonation
          • Feb 2010
          • 391
          • hnami
            service technician
            • Nov 2023
            • 166
            when you use forced upgrade
            It doesn't matter what version you are using. If your firmware has a patch, it is an upgrade file, not an altboot.
            I have the link of the complete altbOot file
            Be sure to use two files "DISABLE_DATA_BACKUP" AND "FORCED_UPGRADE"
            XeroxAltalink_C8130-C8135_ALTBOOT_system-sw114.009.011.28800 - AltaLink C8130 / C8135 / C8145 / C8155 / C8170 Color Multifunction Printer - Xerox
            • CanonTech1987
              • Apr 2024
              • 13
              hnami can you give me the link for ALTBOOT firmware for the Xerox Altalink B8170 please?
              • hnami
                service technician
                • Nov 2023
                • 166
                What version you need?
                • CanonTech1987
                  • Apr 2024
                  • 13
                  The last one please
                  • lucha2
                    • Feb 2024
                    • 1
                    after an update the scanner and copies no longer work because it no longer installs the scan engine function.
                    any software I try to load only these three options come up.
                    can you help me with a special altboot? Thank you.
                    • hnami
                      service technician
                      • Nov 2023
                      • 166
                      I found 81 series special files on specialaltboot.com
                      • hnami
                        service technician
                        • Nov 2023
                        • 166
                        Originally posted by lucha2
                        Good morning. If possible I also need this file for B8170 [ATTACH=JSON][][/ATTACH]
                        You upgrade c model by b model firmware because different firmware doesn’t support scan engine
