I can not clear error code 10-350 an over heat fuser error code. I am a tech. and I replaced the fuser and entered service mode with front door open to try and reset error and error returns instantly. Any ideas?
Xerox 3535 Error Code 10-350
Set NVM Location 744-003 to 0
Did you reset NVM location 744-003 to 0 ?
If the fault was declared three times, this NVM has to be reset.
If you don't have a copy of the RAP I can email you one. I can't post the RAPs on this site anymore like I used to do in the good old days.
JorgeXcalak@live.com -
10-350
I can not get into the service mode to reset the NVM? Everytime I try to enter service mode with PW 6789 the screen returns to error code 10-350. I also can not connect with the service laptop.
I tried entering the service mode with door open and closed but no luck.Comment
PWS Connection
What happens when you try to connect with the PWS?
What diagnostic tool version are you using? Latest for the EPC is 3.10
This is usually a no brainer. You plug in, launch the tool (Programs, Xerox Applications, Xerox Product Tools, DC3535, and connect.
If you're using a USB > serial converter, make sure com port that the USB converter is using is set to 1Comment
gpolcino
gpolcino
010-350
Hello. I have the idem problem. The machine gives this error to me 010-350. Entering in CE Mode as I make to unblock the machine? Scuse me my English is very poor. ThanksComment
