Problem printing from tray 6 on Doc 250
  • Oktobernv
    • Mar 2009
    • 38
    I just installed a High Cap feeder (tray 6) on my Doc 250
    I am not able to print from tray 6
    When I open Photoshop and select print, I now see an option for Tray 6 and Tray 6 oversized.
    I select Tray 6 oversized (I am printing to a 12x18 sheet)
    The document is transferred to my Spire cx250 with no issues.
    It processes the document in the process que and then sends it to the print que.
    Then I get an error that says "Tray 5 is out of paper"
    But I am NOT trying to print from tray 5, I am trying to print from tray 6.
    If I view the spec on the document in my jobs que on the Spire it DOES show Tray 6 as the intended paper source.
    What am I missing??
    Thanks in advance,
    Rob
  • xcopytech
    • Aug 2006
    • 1783
    check firmware level on dc 250.
    must have at least 1.231.5 if you want to use ohcf
    • TechMate
      • Mar 2008
      • 285
      Hi. Check the page setup of photoshop (not the printer properties) if the paper source is selecting the bypass tray (tray5). This overwrites the printer selection even if you select tray6 under printer properties. thanks
      • xcopytech
        • Aug 2006
        • 1783
        try to make copies. if you can make copy from ohcf then go to xerox web site and download sp 1, sp 2 and tray 6 patch for spire cx 250
        • Oktobernv
          • Mar 2009
          • 38
          Thanks XCopy!
          Thanks XCOPYTECH!
          You were RIGHT ON with your info.
          I needed to update my Spire cx250 to the latest "patch" for Tray 6.
          Installed the patch and it prints perfectly.
          Thanks again to all who keep this GREAT resource working.
          Rob in Vegas
