DC250 touchscreen is not calibrated
  • vaian
    • Jul 2011
    • 8
    [Misc] DC250 touchscreen is not calibrated
    hello everyone
    Please help me with information about the problem that occurred to me recently, touchscreen is not calibrated DC250 printer, that if you click on a function has to do with 1-2cm below ... at the top of the display is smaller deviation in the bottom reaches about 2 cm. Please tell me your opinion your. I hope to be quite clear.
    Thanks.
  • bojans
    • 1313
    Re: DC250 touchscreen is not calibrated
    Hold 1, 3, and 0 and Power on.
    Use the pen which is attached on the back of LCD and touch intersections on the screen. You'll have two different screens to touch. After that power off machine.
    • vaian
      • Jul 2011
      • 8
      Thanks for your prompt response. You do this calibration as soon as possible (most definitely tomorrow) and I come back with information. Have a good day.
      • bojans
        • 1313
        Enjoy
        • vaian
          • Jul 2011
          • 8
          Hello, you return to the display calibration problem ... I went into the calibration program and unfortunately we did not manage to push than the intersection of lines at the top of the display. The calibration is so great that the bottom does not even reach senses.
          If there are other alternatives can help me.
          Thanks in advance
          • bojans
            • 1313
            Sorry my friend but you'll have to replace that touchscreen. Calibration sometimes helps, but the problem that you described is the first symptom that the screen has gone bad.
            • vaian
              • Jul 2011
              • 8
              Thank you for advice and please tell me if you know about the price rises a touchscreen in the event that I want to change it and if you can replace just the broken and not the entire monitor.
              • amadeusmbi
                • 51
                Thanks in advance
                Welcome to the club
                You can try to verify connectors but bojans have right...
                replace that touchscreen (not entire UI)
                "Opportunity is missed by most people because it is dressed in overalls and looks like work. "
                • shamsupa
                  thaks dear
