Xerox 3535 error code 102-372
  • Ron King
    • Aug 2011
    • 12
    [Error Code] Xerox 3535 error code 102-372
    Hello. I am having a problem with my Xerox DC3535. The 3535 does not go any further than one blinking light in the startup process. A error code 102 372 comes on within 15mins. I have changed out three boards, all the memory and harddrive to no avail. Was wondering if anyone been successful in getting their 3535 to boot up beyond the one blinking light? What component is plaguing me?
  • adriansto
    • 2369
    Re: Xerox 3535 error code 102-372
    Check your PM
    • JustManuals
      • Jan 2006
      • 9865
      This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
      Paul@justmanuals.com
      • Ron King
        • Aug 2011
        • 12
        I'm not sure what a PM is. Where is it located and what does PM stand for?
        • adriansto
          • 2369
          Originally posted by adriansto
          Check your PM
          Personal ( private ) message. On top of you web page you'll see Notification menu
          • Ron King
            • Aug 2011
            • 12
            Thanks you very much. I will go through each document and procedure.
            • adriansto
              • 2369
              I hope you are lucky men.
              • johnner66
                • Mar 2009
                • 265
                TRY change the sub dc voltage 3.38 v god luck
                • Ron King
                  • Aug 2011
                  • 12
                  Looked at the four documents you sent and we have made every change (and a few more) that has been suggested. Any other advise?
                  • Ron King
                    • Aug 2011
                    • 12
                    Will give this a try. Thanks.
                    • Ron King
                      • Aug 2011
                      • 12
                      Will try. What is the part number?
                      • Ron King
                        • Aug 2011
                        • 12
                        Does anyone out there know the part number for a sub dc voltage 3.38? And how does this parts effect the start up process? Are there any other possible reasons this DC3535 will not complete the start up process? Any feedback is appreciated.
                        • Ron King
                          • Aug 2011
                          • 12
                          Does anyone out there know the part number for a sub dc voltage 3.38? And does this effect the start up process? Are there any other possible reasons this DC3535 will not complete the start up process? Any feedback is appreciated.
                          • sparky1
                            I am also having the same issue could you send me the documents you sent to ron via PM please, your help is appreciated.
                            • adriansto
                              • 2369
                              Do you have service manual and pws for this copier ?
                              Service manual = edoc or pdf format ?
