docucolor 12 HELP!!!
  • Gabriel_619
    • Jan 2008
    • 13
    Hello, here's my problem.....i have a docucolor 12 with the fiery x12 version 1.5, but the fiery got stolen , a friend of mine let me borrow his fiery (same model and same version). I already install it in my computer and its connected to my doc12,when i send something to print NOTHING HAPPENS! the fiery does the rip but is not sending it to print and on the doc12 it says "network controller error"
    Please help!!!!
  • xcopytech
    • Aug 2006
    • 1783
    dc 12 fiery
    hi,
    first check have you connect cables in proper way. you have print and scanner cable.
    second wait to machine and fiery come to ready, and theh try to print configuration or test page from fiery.
    if you can not print test or configuration page from fiery, then you may have problem with cables or with fiery.
    br
    • Gabriel_619
      • Jan 2008
      • 13
      Originally posted by xcopytech
      hi,
      br
      i already check the cables and nothing happens...i dont know if this is the problem: the fiery doesn't say that is ready it says idle on the bottom of the fiery name.
      i did try to print a test page, but i got the same result NOTHING
      • Gabriel_619
        • Jan 2008
        • 13
        Originally posted by Steve0
        Check your network first.
        you can ping to Xerox machine from your computer.
        Good luck
        i did try to connect to the fiery to do the websetup, but for some reason i can't do the setup because of the java application...i can connect to the fiery but i can't connect to the websetup to change the configuration
        • xcopytech
          • Aug 2006
          • 1783
          dc 12 fiery
          hi,
          go on xerox web page, support and drivers and download 1-56ps patch, install it and your machine will work.
          also can download composite patch (about 450MB) and install it. That will upgrade your fiery software.
          br
          • Gabriel_619
            • Jan 2008
            • 13
            hi,
            br
            i can't find the patch 1-56ps, is that the patch #?
            • xcopytech
              • Aug 2006
              • 1783
              dc 12
              hi,
              yes, that is small patch about 60kb,
              when find and download them, it should be download to the fiery with command work station, wait 60 seconds, and restart fiery, then you should be possible to print configuration and test page from fiery.
              br
              • Gabriel_619
                • Jan 2008
                • 13
                hi,
                br
                do you have the direct link?, cause i cant find it
                • xcopytech
                  • Aug 2006
                  • 1783
                  dc 12
                  post your email, i will send it to you.
                  • Gabriel_619
                    • Jan 2008
                    • 13
                    mgmprinting@sbcglobal.net
                    thanks!!
                    • Gabriel_619
                      • Jan 2008
                      • 13
                      Thank you so much for your help "xcopytech"
                      you are a GENIUS!!
                      • TrimChe
                        trimi_12@hotmail.com
                        can you send me link por pat 1-56 please !!!
                        • artphil
                          • Aug 2008
                          • 155
                          Patch
                          Hi Guys,
                          Please send met the link to the patch.
                          I encoutered the same error.
                          Kind regards
                          Artphil
                          artphil@gmail.com
                          • accuratepress
                            • Oct 2008
                            • 11
                            Downloads
                            Is there anything I can download and burn to a CD that my Fiery X12 will start from? Right now it hangs at loading after going through the hardware check. Neither the Doc 12 or my Mac sees the Fiery at all, so downloading something to it won't work.
                            Thanks for any help.
                            toast@accuratepress.net
                            • dksrinivasrao
                              network controller error wiht dc12
                              Please help!!!!
