Doc250 error code 094-322
  • Bruno Marques
    • Apr 2025
    [Error Code] Doc250 error code 094-322
    Got this error code 094-322 can someone help me out please!!
  • livewire
    • Sep 2011
    • 607
    Re: Doc250 error code 094-322
    This is Second BTR Retract Failure
    • Bruno Marques
      how can i solve it???
      • johnner66
        • Mar 2009
        • 265
        replace the clutch rear of machnice that turn the btr roller good luck ..
        • maich4s
          • Mar 2009
          • 86
          hi,causes for this might be its full of waste toners.remove the 2nd btr from the machine clean it well remove all the bits and pieces of it then return it back.this has worked for me.
          • Bruno Marques
            Problem solved tkz to all!!!
            • welnu
              hi, having same problem, how did you solve the error, thanks
              • SeniorTch
                • Jun 2017
                • 116
                check, clean or replace the front door interlock
                • welnu
                  thanks seniortch, problem solved by replacing the connector of transport assembly, rear of the machine
