Error 010-330
  • neetosena
    • 6
    [Error Code] Error 010-330
    Hello,
    Please need some help!
    I am Brazilian and I'm using google translator to ask this question.
    I have a Xerox 4110 that recently is giving an error code 010-330, is that code regarding a problem in the fuser, which could be seen already open the machine, but apparently did not see anything.
    thank you
  • Exok
    • Jun 2011
    • 750
    Re: Error 010-330
    10-330 indicates a problem with fusing unit drive. Check the condition of the drive units.
    This can also be caused by worn bearings on the fuser rollers.
    Replace upper and lower fuser rollers with bearings. If there is a lower roller cleaning blade installed, replace that too.
    • neetosena
      • 6
      Re: Error 010-330
      Good afternoon, Exok
      You would have a Xerox 4110 manual how to do this?
      thank you
      • adriansto
        • 2369
        Re: Error 010-330
        If you have pws there is edoc for this machine.
        • neetosena
          • 6
          Re: Error 010-330
          Please help me, I have this problem for some time now and the machine is stopped without service and do not know how to solve.
          Would detail how I do, I'm not one technical terial passes some step to demontar the machine and see what could be this error and if you can send me this technical manual by email: neetosena@hotmail.com, would be grateful .
          Thanks again
