T98-006 SF 5130
  • bowen6023
    • Apr 2017
    • 6
    T98-006 SF 5130
    So i have tried every mode and even clearing this error tried forcing firmware and still cant get that to work get light blinking looks like its working but never finishes
    i think its the main PCB but it could be Sub PCB anyone had this issues before or good guess which board.
  • Iowatech
    Not a service manager
    • 3933
    Re: T98-006 SF 5130
    If this is like the older Risos, I don't think you have to replace any boards for that error, I think the error code had something to do with the drum disagreeing with the rest of the machine or something. But I've been offline long enough that I'm not sure anymore. Sorry.
    If you are still here and have the time to try a suggestion from an old timey Riso tech, start with the machine off and hold the "Reset" key down while turning the machine on. Keep the key depressed for 5-10 seconds, I usually waited until the motors stopped initializing.
    Sorry if this was a waste of time.
    • 20gaugeO/U
      • 553
      Re: T98-006 SF 5130
      Yep had 1 do this
      run protected test mode
      #1198 to restart MECH PCB
      Memory then load new firmware cause tech support says it will come back if you don't
      • TecnoChile33
        • Nov 2023
        • 1
        Originally posted by 20gaugeO/U
        Re: T98-006 SF 5130
        Yep had 1 do this
        Developing a Reputation as a Problem-Solver to restart MECH PCB
        Excellent! This helped me solve the problem. Thank you so much
        • ldfrepairs
          • Oct 2012
          • 148
          Where can i download the firmware?
          drugstore-onlinecatalog.com
