Riso CV3030 T01 - 537 error
  • floody
    • Mar 2017
    • 37
    [Error Code] Riso CV3030 T01 - 537 error
    morning all
    I'm after some help, I've been called out twice to a riso cv3030 the user is getting T01-537 error, I know this is the print drum failing to stop at position A, I've took the top cover off to watch the drum, when making the master the drum stops in the correct position with the clamp at the top, but then through's up this error, ive changed the sensor, made 5 masters after another so was working fine but customer said its come back with the same issue, the manual just tell me what the error is but no suggestions how to fix it, ive done very little work on these so any help at all would be great Meter (Master) 238 (Prints) 29559 machine is very clean inside & out
    thanks
