Hello everyone!
I have a Riso SF5030, it started sucking paint badly, I washed the mesh in the drum, and got the error T98-087 : "Test mode adjustments stored in the drum is outside the adjustment range".
Clearing 110 111 through the service menu helps for a few minutes. And again T98-087. Could you please tell me what this error means?
The paint was changed.
The risograph prints blank sheets and the ink is not sucked in.
Thank you in advance for your answer.
