Duplo DP 430 error code
  • sharphead
    • Aug 2009
    • 285
    A customer has above model with the error code E016 can anyone tell me what this means, or would anyone have access to a service manual.
    Any help will be greatly appreciated
  • mastkanis
    Re: Duplo DP 430 error code
    "E016" is displayed
    Does drum shift motor turn when it is
    checked using HELP02*?YES Follow the procedure 5.
    Regulated power supply
    Measure the voltage between the regulated
    power supply, +S (+24) and -S(GND)
    with the tester. Is it +24V?
    Measure the voltage between L and N of the
    regulated power supply with the tester. If it is
    100V, replace the regulated power supply.
    Drive PCB unit&Main PCB
    Does replacing the drive PCB unit solve
    the problem?
    Check the connector and bundled wire
    between the drive PCB unit CN1 and
    the main PCB CN3. If OK, replace the
    main PCB unit.
    Drum limit /center sensor
    position
    Does the drum limit /center sensor status
    when it is checked using HELP05**?
    Adjust the drum limit /center sensor.
    Drum limit /center sensor&Main PCB Unit
    Turn the drum limit /center sensor on
    and off, and use a tester to measure
    voltage. Is voltage normal?
    Replace drum limit /center sensor. or Check the bundled wire. If OK, replace
    the main PCB unit.
    Sideways stepping motor
    Does replacing the sideways stepping
    motor solve the problem?
    شكرا
    • JustManuals
      • Jan 2006
      • 9865
      This Parts & Service manual can now be purchased for $12.7Re: Duplo DP 430 error code
      Paul@justmanuals.com
