RISO RZ-370-EP, a few problems
  • papertiger
    • 6
  • papertiger
    • 6
    Re: RISO RZ-370-EP, a few problems
    regarding the white line, i'm told it might be just dust on the scanner's optics
    I guess we'll have to take off the glass and clean the scan-head to check this ?
    is there any kind of built-in test we could run that would show if the problem is on the thermal print head ?
    thanks in advance !
    ps: i forgot to mention in the original post, is suppose it helps to know : the counts on this machine are 186 masters and a little over 89.000 copies.
    • Iowatech
      Not a service manager
      • 3933
      If you haven't tried resetting the operating memory, you might try that. Irregularities in the local power utility can cause voltage surges, which will cause wrong values to occur in the machine's operating memory, which will cause all manner of undesired operation. To do that, hold down the Reset key while turning the machine on, and continue to hold the key down until the display shows ready. Do that only once.
      That being said, the print length problem could be from an errant piece of master material on the drum. Or check the length sensor in the paper tray to make sure it is in good shape.
      Hope that helps
      • papertiger
        • 6
        Hi,
        thanks for your answer, sounds like something we could try indeed
        regarding the print length problem, the drums and masters are fine (we have the same problems with all the drums, so it's definitely something in the machine), nothing there.
        From what I understand, the size of the master (A4 or A3) is determined by the size of the paper detected in the paper feed tray. So, if our masters are created properly in full A3 size (and also only created in A4 when we place A4 paper in the feed tray), that should mean the sensor is working fine, right ?
        Is there any way to make sure of this ?
        Thanks again!
        Hope that helps
        • papertiger
          • 6
          I was able to enter Test Mode and run some simple tests :
          _the sensors are fine, so I suppose our print-length problem is indeed mechanical. Either it was restrained on purpose, which was said to be likely by the person who sold it to us, or else something's not working properly.
          _I ran the print tests, and our thin white line is always there... I checked the TPH voltage, it matches with the one specified on the TPH itself (2073 Ohms). Can anyone give some advice on this ? (could it be any help to increase it ? decrease it ? by how much ?)
          _the noise in the master-removal area (mentioned in my original post) is always there, but not systematic. At some point the noise was heard again, not as loud as previously, and the machine gave me an error code P-89-350. Couldn't find it in the Service Manual. Pressing the Reset key, made it go away.... Any idea on this as well ?
          Originally posted by papertiger
          Hi,
          Thanks again!
          • jermyth
            Riso dude
            • Mar 2011
            • 437
            Error code p89-350, master compression plate: incorrect position. The clamp unit was not in the clamp open position and the compression plate was not in the home position when the drum started its movement. My first guess is the compression plate is cracked. Maybe somthing out of time in the disposal unit.
            As for the image area does the unit print a full test print from test mode on your larger paper?
            Does the unit fully scan down the page? How about enlarging?
            Is something blocking in the optics or on the underside of the glass?
            Good luck.
            • papertiger
              • 6
              thanks for your advice
              we'll try to have a look at the disposal unit, indeed this is where the problem seems to be
              what's strange is that it really isn't systematic, it only happens every once in a while,
              I think it tends to happen when a master is created after a new stack of sheets has been loaded on the paper tray (so, when the paper feed tray is moving up in "active" position while a master is ejected)
              we'll look into that
              regarding the printing area, the test mode only prints partial copy too
              nothing to do with the scan apparently : the unit is fully scanning, and masters are fully created
              the technician who sold us the machine is pretty confident that the machine was intentionally restrained to only print A4
              he's looking for the adequate part, and should come over to fix this (and hopefully, the other issues too..)
              we'll let you know!
              (but of course, any additional advice is more than welcome at this point!)
              Good luck.
              • Iowatech
                • 3933
                If it is a mechanical problem, you might want to pull the back off and look for a solenoid return spring that popped off on one side. It sounds like maybe the one that is on the solenoid that controls the movement of the of the pressure roller might have come off.
