Brother MFC-J6910 Error Code 75
  • dzewo
    • Oct 2013
    • 36
    [Error Code] Brother MFC-J6910 Error Code 75
    Good day
    MFC-J6910 had a damaged Maintenance Assy so a new one (plus ASF drive Assy) was ordered. Now the MFC greets me with error 75 (unable to clean 75) every time it boots.
    1. There are no foreign objects in the printer
    2. Carriage motor operates
    3. New ASF Assy + new Maintenance Assy installed
    I would be grateful for any advice on how to tackle this problem.
    • 22801
    Re: Brother MFC-J6910 Error Code 75
    What we have here is a head capping failure ... recheck your install of the maintenance unit.. connections to the carriage drive motor .. ASF drive assembly.. or something blocking the path
    • dzewo
      • Oct 2013
      • 36
      Done that already. The carriage moves on its own from left to right when the MFC is turned on. It also docks the maintenance unit.
      • Elmtech
        • Nov 2013
        • 155
        Check for a dirty carriage encoder strip. If it gives a false reading the machine will think the carriage is obstructed.
          • 22801
          BUT does the cap move up to meet the carriage? just because it "docks" doesn't mean the caps move up.. I had to go behind another tech and straighten this same issue out from his work.
            • 22801
            that would be a code 76.
            the encoder strip could be dirty or behind the optical sensor causing a 76 error
            • dzewo
              • Oct 2013
              • 36
              It does rise. I'll upload a movie showing the behaviour of the printer.
              Did that too, even though it is connected with error 76 rather than 75.
                • 22801
                so are you getting BOTH error codes or has it now switched?
                • dzewo
                  • Oct 2013
                  • 36
                  No, only error 75.
                  The machine in action.
                  Does anyone see any unusual behaviour?
