Brother MFC L-3750 CDW new toners wont reset.
  • tonerjockey
    • Apr 2014
    • 553
    Hi guys, the customer said that it asked for all 4 toners. they installed all 4 new OEM.
    the 3 colors worked, but the machine still wants a black. brother sent them another, and walked them thru firmware and the manual toner reset. nothing worked.
    i see in the parts book there a part called the "cartridge sensor relay flat cable". the diagram shows the sensor, and the cable but separate with an item number 9 on the cable. nothing pointed to the sensor. that's on page 1 of "frame" chapter.
    does anyone know if the part number D00HND001 is both, the ribbon cable and the sensor?? or is the sensor not spared?
    or has anyone run into this issue and found a resolution?
    thank you very much, Jim
    • 22801
    Re: Brother MFC L-3750 CDW new toners wont reset.
    Hey jim, I would question the LIFE left on the K drum ( K printing used more )
    have seen this time and again
    • tonerjockey
      • Apr 2014
      • 553
      Hi, the machine was asking for the toner though.
      i guess i can go there and try resetting the BK drum and see what happens.
        • 22801
        yes toner will be requested if the drum is over life
        • tonerjockey
          • Apr 2014
          • 553
          oh cool. thanks Phil. i will try that and let you know.
          have a great day, Jim
          • tonerjockey
            • Apr 2014
            • 553
            Hi guys,
            Ok so the machine only had 3220 prints on it. The drums we're at 80%.
            I cleaned the toner sensor contacts. Then took the contact board out, and 2 of the 4 wire connectors were touching.
            I insulated them with electrical tape but no change.
            So I told them it may need a main board and or a sensor relay board which isn't spared by brother.
            They have had it 2 years so I told them to contact Brother and see if they might give them a refurbished replacement even thought it's out of warranty.
            Thanks for your input.
            Have a nice day, Jim.
            • Dickie
              • Nov 2011
              • 190
              Most brother toners have a one time reset gear on the side of the cartridge. This only works on first rotation after installation then falls out of mesh and will not reset after that unless you take it apart and reset the gear to it's original position.
              This is usually a problem with aftermarket toners but can also happen with originals sometimes if they have been thrown around and the gear falls round before installation or it just misses the reset switch inside the machine when activated.
              As such there is a manual reset available to get round this.
              Just google the machine number with toner reset and a You tube video will come up showing the procedure.
              It can be a pain to do, if you do not hit the two keys at exactly the same time it does not respond. Also if the door open message changes whilst doing this, you need to close it, and re-open it to get the message back, before trying again.
              I have had machines that respond 1st time and also ones that take 20+ attempts to get in
              Good luck
              • tsbservice
                Field tech
                • 7897
                OP already tried 2 different toner cartridges and manual reset. Either high-voltage power supply PCB or Main PCB is dead.
                High-voltage power supply PCB is one and the same for following models and if you find one for parts may give it a try:
                DCP-9030CDN/L3510CDW/L3517CDWDCP-L3550CDW/L3551CDWHL-L3290CDWMFC-9150CDN/9350CDWMFC-L3710CW/L3730CDN/L3735CDNMFC-L3745CDW/L3750CDW/L3770CDW
                • tonerjockey
                  • Apr 2014
                  • 553
                  Hello, i dont k now what happened to my follow up right after, but its gone now. maybe on another "reply to sender"??
                  anyway, the CRUM chip contact on the machine side, i removed the cover and found two wires that appeared to be touching. inside, are bare contacts than can touch.
                  i wrapped them with tape, but no improvement. and the board they connect to, small easy access, isn't spared separately. so, thank you Brother.
                  Jim
                  • monitech545
                    • Apr 2020
                    • 2
                    1 open the cover manu 4 times up arrow key maintenance toner supply and reset
                    Best printer repair in dubai uae,uaetech,copier machine repair in dubai , website development in dubai
                      • 22801
                      he has done manual reset.. please read all posts
