Brother MFC-8870cdw error OE
  • gideon
    • 283
    I have the manual and check the control panel connection and cable and all connection on main PCB.
    The display of Brother comes on and the screen going blank and error OE comes on.
    No motor running etc.
    If you find a solution beside of replacing the main PCB please let me know.
    • 22801
    Re: Brother MFC-8870cdw error OE
    that's the only one that worked for me .. had to replace quite a few of them.
    • allan
      RTFM!!
      • 5459
      0E = program error.
      As per manual if firmware does not fix it replace main PCB.
      Whatever
      • tsbservice
        Field tech
        • 7899
        Are you sure about error code?
        Are you sure about model??
