Im totally lost with this printer/client
New Brother MFC L5900dw machine that print nicely it worked frome june 2020 to november 2020 perfectly, but now since mid november the copies are light almost unreadable when copying blue pencil ink only, the other part of the page is fine. they use the same pencil brand and color as they used before, same paper, they have a old MFC-2700W that do it perfectly same pencil ink, same paper at their other clinic
If I manually increase the contrast and density, the copies are fine, but this is a huge hassle to do every time and we shouldn't need to do so. Also, there does not seem to be a way to make increased contrast and density the default settings.
The problem is the same whether copying from the ADF tray or the glass.
Brother sent us a replacement machine, and we transferred the same drum and genuine Brother toner cartridge from the first machine to the second, and the problem persist. we tried another compatible toner also
I contacted brother like 3-4 times, did everything they asked with the client, nothing they can do about that
Sorry for my bad english
