Brother MFC-J6920DW - white stripes
  • spree
    • Jun 2012
    • 211
    Hello, please do you have an idea, what to check?
    See photo.
    I clean two strips (encoder strips) where print head runs and it did not solved. Paper come out A4R (Letter R).
  • Gift
    • Mar 2011
    • 2444
    Re: Brother MFC-J6920DW - white stripes
    See photo.
    [ATTACH=CONFIG]51599[/ATTACH]
    How do the printhead / nozzle test pattern look like? I think you can start the print head test + cleaning preocedure if you tab the remaining-ink button from home screen.
    • spree
      • Jun 2012
      • 211
      Here I scaned nozzle test pattern and one raw (black) at the text is missing. But the cubes look like O.K.02.jpg
      • Gift
        • Mar 2011
        • 2444
        OK that's odd - nozzles seems fine but it still fails to print a line at some point. You can try and perform a calibration/alignment from the same menue but I'm afraid this might not help (still worth a try). As a last act of desperation you can try and do a factory reset from service menue.
        • spree
          • Jun 2012
          • 211
          I made it, PF ENCODER DISK was dirty.
          All is working fine.
          Thank you for you help.
          • Gift
            • Mar 2011
            • 2444
            Thank you for posting the solution.
