Brother MFC 8910DW
  • hosbiz
    • 13
    Brother MFC 8910DW
    Blank copies after fuser error
  • tsbservice
    Field tech
    • 7904
    Re: Brother MFC 8910DW
    What have you checked so far? Prints are good?
    • dalewb74
      • Feb 2018
      • 1107
      fuser error message is what exactly??
      • hosbiz
        • 13
        Error Code 6A. The error dis appear after replacing the Center thermistor...But the machine is gives Blank copies
        • Hrca
          • Jan 2022
          • 9
          This is what I've found in the service manual: "Electric discharge that may be caused by dirt on the corona wire of the drum unit was detected." So yeah, not quite helpful
          • Gift
            • Mar 2011
            • 2444
            That's odd usually you don't really interfere with anything delicate during a fuser swap/repair - (few screws in the rear area). If you force a print to stp (opening a cover) you can check if there's any image on the drums/transfer. Are you shure the unit was OK before the fuser error?
            • hosbiz
              • 13
              Copies are fine before the error. I think the problem is with the image processing because if i move the charger cleaner to the center , there will be a solid black line on the copy.
              • Gift
                • Mar 2011
                • 2444
                Yeah that's likely - or does this model has some kind of laser shutter mechanism that won't work? Usually one would expect some "machine error XX" message if there's something wrong with the electrical parts.
