Duplex scanning on Brother MFC9340-CDW are blue
  • depanninfo06
    • Mar 2018
    • 13
    Hello,
    I have just changed the scanner lamp of the adf on my brother MFC-9340CDW, no problem on the front side in black and white but in color the back is all in blue. You can see on vuescan below
    I tried to make Acquisition of White Level Data with code 55 like on SM but get an error :scan error adf in maintenance mode.
    Does anyone have any idea where it could be coming from?
    Thanks in advance
  • dalewb74
    • Feb 2018
    • 1125
    Re: Duplex scanning on Brother MFC9340-CDW are blue
    did you retrace all your steps to make sure all connections were seated properly?
    • depanninfo06
      • Mar 2018
      • 13
      Finally, i got the solution. I tried with another cis scanner module, go on maintenance mode and make white registration (Code 55) and all is fine.
