Brother Mfc-8950dw unable to reset drum counter
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Posting this in the hope that it will help somebody in the future. Followed the Brother Mfc-8950 factory instructions to reset drum counter Which are:
    Press the stop/ exit key to interrupt the error
    Press menu on Lcd display
    Use arrows to scroll to Machine info and select it
    Press reset menu
    Press drum
    In this case no reset menu option was available on the Lcd. Used alternate method to successfully reset drum:
    Open front door
    Hit the asterisk key
    drum is displayed....select it and counter reset is performed.
