LaserJet M521dn - Scanner Error 16
  • KJEpps
    • Jun 2012
    • 63
    I'm in a bind. I have a LaserJet Pro MFP M521.
    The customer initially brought it in for not initializing. I replaced the Formatter Board and all was good for about 4 days. Then the customer reported that it was getting a Scanner Error 16 at power up, but that error is not listed in the User Guide or the Service Manual. In troubleshooting, I replaced the Formatter Board a second time.
    Does anyone have an idea whether this indicates that it is the Scanner Assembly or the ADF Assembly that has failed?
    TIA
  • Wild Bill
    • Jul 2005
    • 774
    Re: LaserJet M521dn - Scanner Error 16
    Scanner Error 16
    Description
    There is an internal hardware error with automatic document feeder (ADF).
    Recommended action
    Replace the ADF
    Izzy
    • KJEpps
      • Jun 2012
      • 63
      Thanks, Wild Bill! I'm curious. Where did you get this info? My version of the Service Manual didn't have it.
      • Wild Bill
        • Jul 2005
        • 774
        Laserjet Pro400 - Scanner Error 16 - HP Support Forum - 5376478
        Ye its a different model but I couldnt find it in the damn manual and I have all. Ive been researching since I posted. I would pull the adf and try it as a flat bed and see what happens. Or check connectors.
        Izzy
        • Lance15
          • Jun 2015
          • 1073
          Probably the same or close to the same as the old M2727 scanners. Piece of S*#t!
