hp P3015
  • tcypy1961
    • 773
    [Error Code] hp P3015
    error code 49.FF04 causes and repair please; saw through a search it said most likely firm ware update???
    Thanks!!!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4998
    Re: hp P3015
    Processing bug.
    Download and install new firmware:
    HP Software and Driver Downloads for HP Printers, Laptops, Desktops and More | HP(R) Customer Support
    • boscru
      • 31
      Re: hp P3015
      turn off the printer, clear the print queue, and restart. should be fine. usually happens when printing from the web, but not always. if it's on a network you may have to clear all user's print queue's
      • theengel
        • Nov 2011
        • 1784
        Re: hp P3015
        If nothing else works, you might have to replace the formatter. But usually, this is just a corrupt job. Keep it off the network when you turn it on. When you get to ready, then plug in the network. If it starts processing a job, that means there's still something in the queue.
