Scanner error 13, MFP 477
  • HuronMan
    • Jul 2009
    • 68
    I have an HP mfp477fnw that displays a scanner error 13 when its powered on. I've done the hard reset and it's plugged directly into an outlet. I reseated the ribbon cables from the scanner to the board they're plugged into. I don't see any movement from the scanner unit and no exposure lamp lights up. It won't print any test prints. Thanks for any help.
  • Printerdude
    • May 2015
    • 119
    Re: Scanner error 13, MFP 477
    Are you sure the display is showing scanner error 13??? or are you guessing a error 13 is scanner issue?
    Error 13 are usually related to paper jams.
    Error 30 are related to scanner errors.
    What is the exact error message?
    • HuronMan
      • Jul 2009
      • 68
      And yes, it's a guess. I've recently been forced to service these.
      • Printerdude
        • May 2015
        • 119
        Have you reattach the cables to the scanner itself?
        Does the scanner assembly move freely?
        • Laserrick
          • Oct 2014
          • 13
          I've seen this before, the scanner is shot. Replace the entire unit, no parts available - Integrated scanner assembly (M477) CF377-60104. You can get it from Ed at Metrofuser 908-245-2100 X129
